ok im having abit of trouble with sketchup. how do you make a circle cutout? i can make circles on the box but i cant get them to be cutout. and how do you get like ports to extend into the box?? if anyone has any other tips id greatly apreciate them
And far as the best connection ever.......
get a huge fucking battery, cut the top off, drop an alt in there and then pour all that into your big amplifier. or just smelt them all together.
use the push pull to do circles
R.I.P!
(Nov-29-2009)
92 explorer
current build
oh ok thanks
and port is the same push pull
R.I.P!
(Nov-29-2009)
92 explorer
current build
oh ok. are there any other things that would make it abit easier for me?
just play with it to get usta things
R.I.P!
(Nov-29-2009)
92 explorer
current build
ok. yeah i was really good on autocad my freshman year.(in my junior year) but then the class ended and i never was able to use it again.
i started using it bout a month and a bit ago an at first i gave up then got back on it and kept playin around and now its easy as hell
R.I.P!
(Nov-29-2009)
92 explorer
current build
yeah thats how stuff is for me. if i do give up on something when i do go back to it i master it right away. and then im wondering what was soo hard about it before. lol.
