95pimpalass Posted January 9, 2009 Report Posted January 9, 2009 Im going to be installing a head unit for the first time. What tool/s do i need to find the ACC/IGN and Battery Lead? The car just has the wires hanging so i can't just buy a kit. Gracias.
Stephen Posted January 9, 2009 Report Posted January 9, 2009 Im going to be installing a head unit for the first time.What tool/s do i need to find the ACC/IGN and Battery Lead? The car just has the wires hanging so i can't just buy a kit. Gracias. what car? year? i can prolly get you a color chart for your wires but if not a multimeter will do. you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
95pimpalass Posted January 9, 2009 Author Report Posted January 9, 2009 mybad its for a 94 Toyota Tercel. It already has an amp for the mids/highs so I dont think ima hook up the speaker wires, only the rca, if thats kool. Where can I get an alright multimeter for a good price?
95pimpalass Posted January 10, 2009 Author Report Posted January 10, 2009 I couldnt find the ACC/IGN wire from the car, I checked all the wires while the cars key was on ACC with a multimeter, and nothing. What should I do now? but I did get the Battery wire.
Kian Posted January 10, 2009 Report Posted January 10, 2009 Either you check other places or. just hard wire your head unit on and put a switch on that wire for manual on/off. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
Stephen Posted January 10, 2009 Report Posted January 10, 2009 12 constant is blue with yellow stripe 12 acc is gray ground is brown check your fuses you can cook bacon shirtless if you're not a pussy...lol not hatin, but am i wrong here it looks as if the amp is not grounded its hooked directly to the battery. it that the way it should be. DC POWER
95pimpalass Posted January 10, 2009 Author Report Posted January 10, 2009 12 constant is blue with yellow stripe12 acc is gray ground is brown check your fuses Thank You! very helpful.. Ima go check WaSSup..
95pimpalass Posted January 11, 2009 Author Report Posted January 11, 2009 Cheeah! da problem was the fuse for the Stereo. Thanks.
