Soldering 1/0
i was wondering if there was anything to gain by soldering the end of the power and ground that connect to the amp and if so what is the easiest way to do it.
thanks in advance
Theres really no need i dont think, but if u want to, just soldere (sp?) them up and grind them down till they are the right size to fit in the hole, just gives your set screw a lil more to bit into
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
One benefit to soldering the ends is if you have to disconnect / reconnect your amps for any reason. Without the solder on the ends, each time you tighten the set screw, it cuts off strands of copper, so each time you do that you lose more wire. With them soldered, you don't have that problem. Just my 2c.
97 Maxima SE
Bunch of shit going in, check out the build
  • Who's Online   0 Members, 0 Anonymous, 1560 Guests (See full list)
