This is at the top just so you dont skip it, one has 2 tiny dings in the cone, and both the motors have some rub marks and skuffs, but they could be buffed or cleaned up if needed. Purely cosmetic.
If you were drawn by the title then you are the person this ad is aimed at. Mostly home theater guys or pro sound people would be interested. What i am gauging interest in is a PA prototype based on the aura NRT18 neo-radial motor design. The things stopping the NRT from handling over 800 watts started at the cone, they updated this over the 1808 but it was still a paper based cone. Too small of a cabinet and/or too much power and the cone will collapse. The next problem if the cone held up is all thats stopping the tinsel leads from caving the cone in was 2 small pieces of foam glued to the backside of the cone. If the foam falls off the tinsel slap would hit and cause significant damage to the cone. Then you have the coil. 4" edgewound coil that was used was done so to keep production cost down, not for high power handling. I personally helped assemble both these drivers, and have been holding onto one until we finished the second for awhile. Now i have both but am in need of some SPL drivers that can take 4kw a piece for my bassrace car. So im shooting for a kind of niche with these.
They use a TC basket, flat 3 rib surround, Upgraded edgewound coil (not sure the coil we ended up using on this pair specifically but it wasnt cheap!), It has dual nomex spiders with woven leads, and an anodized aluminum cone. I have put about 750-800w rms on one of the two for about a week in my daily driver and it sounded amazing :D and was very loud! Unfortunately single 4 ohm coil is not good for my use. I need to sell the pair, or i will use autoformers on each in my wall, and up the power until they are in need of recone, then we will probably get custom flat wind copper clad aluminum coils, high roll surround, more spiders, and a Kevlar cone and rebuild to try again.
I dont want to butcher these things they are GREAT drivers.
Price for the standard driver can be found here:
http://www.madisound.com/catalog/index.php...acturers_id=121
810$
I am asking 1600$ for the pair or any reasonable offer. I will trade for 2 SPL 18" Subwoofers, or 21" IA DP's.
Pictures:
We have ~10 motors at the shop but do not have the softparts, but if needed dorne could build and assemble them for a buyer if you need them for a pro sound application.
ALSO yes these are ridiculously expensive, but the motors are what make this driver unique and im not trying to make money on this deal i paid ALOT for the motors and to get these things assembled. Theres a niche crowd that could appreciate these so dont FLAME my thread because you cant afford them. I just thought i would try my luck here. If youfind a NRT motor for cheaper please PM me as iwould be interested.
Last i saw motors go for 650$ a piece!
DCAUDIO
BALLS DEEP
This topic is now closed to further replies.
