2 Batteries In Trunk
Ok, quick run down. I will be installing a 200amp HO Alternator with a Kinetik HC1400 up front and doing the big three with all 1/0 gauge wire. In the back I will be placing 2 Kinetik HC1800 in the trunk. This is to power 2 SAE1000d's (90amps each) and a SAX-100.4D (also 90 amps). Each SAE1000D's will be ran at 1ohm and on a single Pioneer TS-W3001D2.
The thing I am a little unclear with is how do I hook the batteries in the trunk up to the front. Do i use a single 1/0 run from the alternator back to the first battery and then piggy back to the second? Or do I run off the front battery back to back batteries.
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
run from the bat up front to the 2 backs, jus go from pos to pos, and neg to neg
*Alpine Typr-R 12"
*JBL GTO 1200.1 Sub Amp
*Alpine PDX-4.100
*Rockford Fosgate Power 6.5's
*Rockford Fosgate Fanatics 6.5's Both in front doors
*0/1 Guage wiring from front Junction Boxes to 120AH Battery In Boot (battery removed because too small for alternator)
*140 Amp HO Alternator
*Alpine Head Unit
-------------------------------------------------------------------------x------------------------------------------------------------------------------
There is three ways you can do this...
1. You can run 2 wires from front to back
2. You can run 1 wire from the front to one battery in the back and then to the other battery
3. You can run 1 wire into a fused distribution block then to both batteries (this is how I run mine)
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Ok, so let me see if i got this. I would take a run off my positive terminal up front and run it to the back. I would then run it into a fused distribution block and them take a run to each battery. Do I then need to have a cable run between the batteries them self?
Also when it comes to wiring up the amps dose it matter which battery I pull from or should I have some sort if positive bus bar? If I use a buss bar can i just hook that up to one of the batteries.
There is no need for a cable between batteries because the distribution block does that already.
Your powering two amps right? Just wire one amp to one battery.
I do box designs.
I will be powering a total of three amps..(2 SAE1000d's and a SAX-100.4D)..
The 100.4 doesn't put that much current. You can pull it from one battery. Or see about pulling it from the distribution block.
Edit: You could run a 4 gauge from the front for the 100.4.
I do box designs.
cool then... If i get a second I am going to try to draw this up and post also...
  • Who's Online   0 Members, 1 Anonymous, 939 Guests (See full list)
