i need help on pickin fuses i will have a 220 amp ho alt and a Kinetik HC 1800 in the hood and 3 Kinetik HC 2400 in the back
here is a lil drawin i did
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
get at least 250-300 amp fuses and will this all be done in 0 gauge?
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
would it be ok just 2 do 300 on all the power and should i do 2 on each wire ?
we have the same batts, you don't have to connect the rear batts to the alternator. just connect it to the hc1800 up front.
what wire do you have? base the fuse size on the max amps the wire can handle.
fuse the 2 runs from front to back(one near the front batt and one near the rear batt) and you can also fuse from alt to front batt
well i'm getin 1/0 when i have the money 4 it
y not run wire from the alt 2 the bat in the back steve did in the hoe...right?
so dont fuse the other 2 batts?
you dont have to but you can never be too safe.
so if i do i would do a 300 right?
You should fuse them if they are far enough away from each other, but if they are right up against one another there is no need since the likeliness of the wires from each terminal to be damaged there is very low. But if you're anal about that sort of thing then yea u can fuse between each batt.
And yes 300a fuse for 1/0 gauge wire, bigger fuse if you are running bigger wire.
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
  • Who's Online   0 Members, 0 Anonymous, 901 Guests (See full list)
