so that is how you do it if you do not have a router
Baylor University
Accounting
flush meaning it is not "sticking out" above the baffle?
Baylor University
Accounting
so you can use a router or create a double baffle and just make the diameter of the circle cut outs different lengths. The one on bottom a smaller diameter in length, and the top piece of the baffle a longer length.
Baylor University
Accounting
the first baffle (which the sub/s is/are mounted to) would be the actual mounting diameter (cutout) of the sub. the "flush" baffle would be about 1/4 bigger than the diameter of the sub.
thanks for the help bro
Baylor University
Accounting
I made the choice of making that flush mount 18.5 inches. Mistake #1 mistake #2 using a dremel to get the hole bigger.(i have no idea what i should of used but it went up in smoke.) Mistake #3 putting the subs in before i found a good place for  the amps. ahhh
two ideas i was thinking for my setup(which will be simmilar) is on the box at the back , you said you had room... or to the back of your seats... either way just make it look clean and your set...
