Ya...I found two Memphis 4kw for 1300 on the soundpressure forums. I might hit him up and see if he still has them.
Those 4kw are current hoggs...strong amps but they need plenty of juice...and if your gonna strap them @ 1 ohm that means each one will be seeing .5 ohms(i may be wrong)...that would work for burbs, not sure about daily. plus these amps are a hole different animal @ 16 volts are higher, not sure what kind of set-up that you are running(12 or 16 + volts). for around $1400 you could get a pair of regular z2's. These come alive @ 16 volts to, but are alittle more efficient than the 4kw..and on a strong 12-volt system would make more power than the Memphis.
supercharged hummer h2
8 Sundown nightshade v'2 Scott Bowman built 4th order bandpass
2 precision power pcx 4125(mids & hi's)
2 Stetsom 14k2e's
alpine ina-w910
dual Mike Singer350 amp alt
8 kinetic 2400 batteries two shuriken bt 120
1 kinetic 2000 under the hood
link to build log:
My link
