Ok so electrical is not a problem. I can upgrade alts, more batts, more 0/1 so its not really that big of a problem.
I need suggestions on amps...the subs are 9918 Dual 2 ohm, and will be in a wall.
So either.. One amp that is 0.5 ohm stable with around 6 to 8kw OR one amp at 2 ohm that has 6-8kw
If I go two amps I can master/slave them at 1 ohm each, so 1 amp per sub.
I've been looking at the Soundstream XXX series, at the 6500D's. At 14 volts they are rated at ~4450watts, but at 16 they are rated at 6500.
Any suggestions would be great.
Keep in mind this is a daily driver, the alternator already runs at 15 volts, so my MLA module will be set at 15 for low, and 16.3 for high.
I know more batteries is a must, and more runs of 0/1, which won't be a problem.
Start throwing suggestions!
IMO the XXX series are pretty pooz unless you're running true 16v (with 18v+ charging/float).
2 Sundown SAZ-3000D's strapped @ 2 ohms will give you about 6-7kw.
Otherwise 2 of the big Zenon's/similar would work well - AB VFL400.1/500.1, Atomic AT5000.1, Cactus 5kw, Hifonics ?, Memphis 4kw, IA 40.1... there's a nice long list there.
Also Rockford T3000's or T4000's?
Edited by Boon
10.x volts fo' life!
just get yourself a pair of dd z2lv's.they should do bout 16000 at 20hm strapped. or just run them one per sub and get 8000 at 1ohm
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
2 batcap 4000's 1 batcap 2000
dual alts.
154@37hz and climbing
http://www.cardomain.com/ride/3231683
http://www.myspace.com/torque150
Yeh cause that's what he asked for..... :rolleyes:
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
he asked for amps for 9918's. they can take a z2 all day long. i know what he said bout power, i was just simply stating what amp those subs can handle. f'n smartass :tease:
2000 gmc yukon
4 sundown Zv3 15's
4 dd m2a's
kenwood kdc-x994
dual alts.
I don't know how deep is your pockets but why not go with Stetsom.... They make those bad boys hit hard... I know i have the same ones.... I had 4 7KD's and they took it like a champ. :hairtrick:
2007 1st West Coast Regional Champ S/Max 157.3Db
2008 1st West Coast Regional Champ S/Max 158.8Db
2009 160db is my Goal!!!
Stetsom's West Coast Rep
Team Stetsom
those memphis 4k watt amps you can find used for around 550-800 per.. pretty sure they do over rated power from what ive seen on here
The DC Integra 3 18s to 6 15 build log
Team_DC-Derrick's Youtube
Team DC Audio
where theres a will theres a wall.......
I just realized Steve has reach Voldemort status, over on JP's site he is the one who will not be named....."We dont speak his name over here, fearing it will destroy us" LOL not even in hush tones
I would look at the Sundown 3000D's, two of those strapped would do the job and right now they are having a sale on them, you could get two and have some change.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
