I want to order a fi ssd 18" dual 2 ohm but dont know which amp
i have an exile 500.1 rite now and was thinking off getting another
one for each coil? the exiles are 500 wrms, 1000 wmax
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
Unless you have alot of experience with amps I do not recommend you run 2 amps on one subwoofer.
There is alot of weekly to monthly mantence(can't spell) that you will have to check.
If the gain or the bass boost moved by accident on one amp it may ruin your sub.
The bass from the vehicle and speed bumps and all other sorts of stuff could through the gain off, expecially if one amp is older and more used the gain might be alittle looser.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
^^^ This man speaks the truth. Sell your 500.1 and get a new amp.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
i here you on that, but i just got the amp
couple days after boxing day so its pretty much
brand new and i always have my amps bolted
down under the seats. but what amp do you
recomend then budget is $300-400
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
Hands down the sundown sae-1200.1. Hell of an under rated amp and there on sale right now for 310 shipped brand new.
http://www.db-r.com/sell/store2/index.php?...products_id=196
Edited by Zade08
are the kicker zx2500.1 any good? i see them on
ebay alot for like $300?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
http://www.stevemeadedesigns.com/board/ind...showtopic=35124
The 1200 will do around 1500 watts at one ohm.
it looks like sundown is the way to go
for amps never had any experience with there amps though?
do they always need 14.4V to put out full rms or are they
power hogs?
98 Dodge Durango
(1) Ported box 33hz
(1) Rear battery
Big 3 in 0/1 gauge
250A Alt soon..
power hogs?
lol This is why I have became a sundown fanboy. All there shit is rated at 12volts. So what you see is actual rms of what you get plus more.
zx2500.1 are nice but a power hog and more power than your going to need for your ssd. If your going to spend that much money on an fi sub why not get the Q18?
