Guest Nismofreak
I have a 1995 Nissan PAthfinder which doesn't like me. I wanted to start the engine it doesn't. It seems likes it want to start but its choking. Is it 19F and is it due to the cold. The car is parked outside
It could very well be due to cold.
If you can get the vehicle started and drive it to an autoparts shop (Like AUTOZONE perhaps) they can LOAD test it and find out if it's good/bad.
Other than that, maybe upgrade to a battery w/ more COLD CRANKING AMPS. More ability to crank in low temps.
Also make sure the battery in the vehicle has as many or more CCA's than the stock batt. Lots of times folks will go the cheap route and not even have a battery in there as good as the stock one, underrpowered for the vehicle, AND THEN start dumpin more electrical strain on it by adding a system.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Guest Nismofreak
I have a kirland signature battery which is crap but I might upgrade to a optima. The battery is fin in the car or it might be the fuel that could of froze, just guessing.
Looks like you found your own problem lol
Only good thing Costco's for is the pizza
Guest Nismofreak
:W: and good prices for optima batteries.  ;D
The flash point of gasoline is bout -97F, meaning that it will still burn at 97 degrees below zero.
Even the -97F mark is gona vary, based on the additives in teh gas.
If there's any water mixed in with the fuel, it can still freeze at around 32F, but that may depend on if there are any alcohols mixed with teh gas.
Methyl alcohol is a common additive u can buy to help keep water in your gas tank from freezing at low temperatures.  :gun:
