Kian Posted January 21, 2009 Report Posted January 21, 2009 Ok so today around 7:00 Am i go and try to start my car and my batts were @ 6.2V. the day before i installed my new Alt and voltage regulator. i need help this is bad. i don't know if it is a fast drain or a slow drain. Thank You Kian. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
banginAltima Posted January 21, 2009 Report Posted January 21, 2009 I had the same problem with me 85 Mustang. The alternator would stay "on" and kill the battery quick. I had a wiring issue deep in the dash and never fixed it. I bought a one wire hook up Powermaster alt. and just bypassed the problem. But from what I understand there is a wire that turns the alt. on or energizes it. Thats your issue Edit: I bet if you touch your alt. even if the engine has not run it will be hot. If you build it, db's will come... NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09). Competition Only Record Holder Trunk 0-500 watts---148.1 2006 Nissan Altima 3.5 SE Currently Rebuilding.... My 150db Plus Trunk Build I do box designs. [benH] 6:24 pm: clipping doesn't really hurt subs [benH] 6:24 pm: being an idiot is what blows subs
Kian Posted January 21, 2009 Author Report Posted January 21, 2009 Thank you. i'm going to go and try it. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
Kian Posted January 21, 2009 Author Report Posted January 21, 2009 iight I'm back. i just tested my front battery and it was reading @ 12.35 volts i disconnected my other 2 battery's just so i can jump my self in the morning if i have to.. but i really cant say its "on" because i was driving it about 2 hours ago. and to me it's around the same temp as my engine is. I will check later today. When i first installed the alt i ran the 0 gauge from batt to alt with fuse, but i never grounded my alt. i grounded it earlier today. Also for my alt plug, i guess it bypasses the internal reg. but i have a the new plug going into my old plug. when i turn up the voltage regulator it reads around 14.7 volts so i know i bypassed it right. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
Kian Posted January 21, 2009 Author Report Posted January 21, 2009 Bump for more help. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
Kian Posted January 22, 2009 Author Report Posted January 22, 2009 So i pretty much think i have it figured out. Whenever i plug these in for my voltage regulator my volt drop. when i unplug it my volts go up. there's the pick. --------------------------------------------------------------- Club 150 (15x.x) Youtube Future Build: 1x 15" T3 TSNS 2x Sundown Audio SAZ3000d Parellel strapped
