Since I bought this truck about 8 months ago or so, I have had problems with it while switching in to 4x4, that it would not get out of 4x4 mode. I figured out how to switch back. But while in 4x4, or turning sharply, or usually to the left, or in rain, the axle will feel really bumpy. So assuming it may just be the axle when engaged in to 4 wheel drive, or just when I turn sharply, that its an axle problem.
Is that what this sounds like? really bumpy turns, and bumpy when switched to 4 wheel drive?
This is lowered quit a bit, I' am thinking its a 4/6 drop, with drop spindles, the whole 9 yards, so I have assumed from the beginning that the suspension or drive train would be screwed up sooner or later due to the drop
The axles are not that expensive, only like $118 each, I have an extended warranty, my mechanic is a really cool guy, I' am sure I can get him to swap these out, as long as I pay for my deductible (axles, cvs not included in warranty)
So, does this sound like it may be the axles ( which I' am thinking myself)
or transfer case?
so when you are engaged into 4x4 and try turning sharply it kinda buckels and bumps as you turn??
that is completely normal in 4x4 if that's what you're wondering, no way around it really
is it doing in in 2 wheel?
Edited by a_steezy
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
If it is just when you turn on when you are are pavement or something hard when you are in 4x4 that is normal because the axles partially lock up so the tires are pulling when you turn. If it does it when its not in 4x4 you are still in 4x4 haha. Some trucks have trouble getting out of 4x4 mine does sometimes but that is somewhat normal. just put in in 2x4 and drive straight slowly forwards or backwards and it should have a small poping feeling and it will shift over to 2x4
98 Jeep Wrangler
33x13.50 super swamper LTB's
Memphis M3 15"
Memphis MCD1000
Optima yellowtop D34/78
Bass Race 129.9
(LBZ Duramax in the future)
Oh dude, somethings wrong, if I was the truck, it would be in pain, and its coming from the axle/ transfer case area, not the wheels. I don't have super swamper's or anything like that, nothing knobby that will cause that sensation of ruff turns ( I know that feeling)
It was lowered, had 20's on it, I sold the 20's got factories back on it, just 16"s nothing fancy- since I bought it, its always had issues switching to 4wd, and out of 4wd, and when in 4wd, the sensation is constant, not while its in 2wd, while turning in the morning, or when wet, like raining as it is today, it will bounce around while turning... I'am already leaning towards axles. I have heard that its possible that a bearing from the CV joint could have popped out, causing that... I guess I want a second opinion ( the warranty has a $100 deductible to just look at it and say whether it is, or not that issue)
I would rather get factory suspension back on this thing, and then be able to put larger rims on it, like 22-24s, its so low as is, 20"s was really hard to squeeze in there.
its night and day difference 4wd to 2wd... in 2wd I can pull burn outs in this truck, no problem, brake stands, I can literally dust most passenger cars on the road in this SUV as is- in 2wd- but in 4wd is when I have all the problems, or while doing u turns, it feels like the damn front end will fall off, and worse while turning
Last year I had a GMC s15 blazer, 4wd, it had knobby tires, and had transfer case issues, that truck would lock up, and not drive after in 4wd for a minute or 2, but it ran smoothly in 4wd at first
if this is on the Denalli, make sure ya check the front diff fluid. they are notorious for leaking out the side seals and lunching the diff. This can also cause jacked up 4x4 engagement being that it is electronically actuated at the diff by a force motor
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
I just took some pics of the axles in the front, I do notice a problem to what I THINK is a problem
Since these had lowering spindles, it looks like the axle is tweeked almost a Z shape, very light Z ofcourse, but this is on flat pavement, and you can see the axle going up about 3-4 inches to the spindle
with the axle in the shape could that cause issues?
I don't have any real problems with the rear differentials, just the common slight delay kick rolling at a red light, then gently hit the gas
I do see that has been leaking a little bit, but again, its all in the front area, no issues in the back area
Iam very happy with how clean these pictures came out.. lol
I said front diff, not rear
Kenwood DNX-893s
2 Dat 4.125's
2 Sundown Zv5 12's
Lots of Hushmat
2017 Comp Vehicle
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
newls1
kingsuv
kingsuv
