Hypnotik DesignZ Posted January 23, 2009 Report Posted January 23, 2009 I was wondering what is needed to run this amp? as of now i got two hc600 and thats about it i want it to be able to pound all day any help Jensen 9511TS~For Sale JL Audio 300/4~For Sale JL Audio1000/1~For Sale Mephis 6.5 componet sets front and rear 4 15" Fi Q's in a 16 cuft box tuned to 29hrz
Neo_frog Posted January 24, 2009 Report Posted January 24, 2009 I was wondering what is needed to run this amp? as of now i got two hc600 and thats about it i want it to be able to pound all day any help Honestly, I had some problems running mine in the beginning but eventually tweeked everything out for max performance and now both of mine can run full tilt without a problem. As of right now, I have 300A alt, 4 Kinetik 2400s, 2 Kinetik 1400s under hood, 3 runs of 1/0 pos and neg (6 total), copper and aluminum 3/8" and 1/4" buss bars all around, Big 3, all soldered...yada yada yada My main problem in the beginning was that every time the bass hit, my new alternator belt slipped and it took me forever to find out because one of my buddies heard it squealing while I was troubleshooting the voltage drop. That's why I have so much in my little car as far as power upgrades. I'd say you need more batteries for sure and a new alternator at the very least. These amps are touchy and blow easily when the voltage goes even moderately low (high 11s). The new ones are better with low voltage, but the 2008 and before kinda need 12+ all the time. EDIT: If you're sticking with Kinetik, I'd say 2 2400s at the least in the bank by the amp. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Justin Posted January 26, 2009 Report Posted January 26, 2009 What about 1 hc3800 would be cheaper than two hc2400. 99 2dr Blazer Kenwood KVT-614 SounDigital SD16k 4 Fi BTL 18s 4 hertz high energy 6.5s comps 4 stock ad244 alts 6 g31s batts 8 runs 0ga
tejcurrent Posted January 26, 2009 Report Posted January 26, 2009 If you have room for dual alts I'd do that with an MLA module. If you could upgrade your alternator to a nice 250-300 unit and add a few more batteries (or 2-3 2400s) you would be in good shape. Once you touch 12.5v I wouldn't let it go any lower with the 4kw. tejcurrent XS Power T3
