******geo Metro Wall Build******
what numbers have you hit in that ride, it super small so it should be huge!
(2007 Chevy Tahoe LT)
Mechman 320A
OEM AGM
D'Amore Engineering HLC-2 Sig Converter
D'Amore Engineering E1500.1
Fi Audio Neo 3.5 12"
how many cubes is that wall ??
i think im going buy a geo metro and put 2 18s in it off 6 k or so for power
R.I.P!
(Nov-29-2009)
92 explorer
current build
how thick is your box?
2x4 frame and how many layers (i forgot what page it was on)
i plan on doing a steel frame welded to car and making as big as possible
R.I.P!
(Nov-29-2009)
92 explorer
current build
1 layer on the sides, back, and top. two on the floor and two for the divider.
edit*: with a layer of resin and mat in the corners and around the wheel wells.
Designs for
one layer on sides nice k thanks alot man i'll be looking to you for advice in the future
R.I.P!
(Nov-29-2009)
92 explorer
current build
try and get a 4 door if you can, a good bit more room for different sub placement options.
Designs for
hows it holding up to the weight i know you've been over it in thread before but once again lazy
and yeah i was thinking a 4 door or even a golf its just hard find something cheap and available right now
R.I.P!
(Nov-29-2009)
92 explorer
current build
