IAMBUMP Posted January 25, 2009 Report Posted January 25, 2009 I'm thinking about buying a new HO alt for my truck when it comes time to do the system and I don't mind spending ~300 roughly on something that will let me run a good amount of power. I want two good high quality 12's that will get loud enough where I won't turn it up all the way haha. Probably some BTL's or DP's or similar. Probably a sundown or 2 is what im thinking for amps. Should I go irragi, mechman, someone else? Any info is appreciated. If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
bobonit Posted January 25, 2009 Report Posted January 25, 2009 I'm thinking about buying a new HO alt for my truck when it comes time to do the system and I don't mind spending ~300 roughly on something that will let me run a good amount of power. I want two good high quality 12's that will get loud enough where I won't turn it up all the way haha. Probably some BTL's or DP's or similar. Probably a sundown or 2 is what im thinking for amps. Should I go irragi, mechman, someone else? Any info is appreciated. Call Robbie at DC Power. Call the 800 number on the website http://www.dcpowerinc.com Thats where I got my 250a for my Maxima. 97 Maxima SE Bunch of shit going in, check out the build Build Log
