Need My Box Design Checked
can someone check the spec on this box for me.
its
39" x 24" x 18.5" outside dim
port
17" x 17.25" x 6 "
the speaker baffle is 1.5"
it should be
6.55 cuft net
102 sq of port
34 hz
but the program i use seem i lttle off from box pro
1993 Mazda Mx-3
Subs: 2 18" DC Audio Lvl 4 D.7
Highs amp: Sundown SAX-100.4
Sub amp: Sundown SAZ-3000D
Electrical:Kinetik 1200 under hood, 2-Kinetik 2400 rear
All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
Be a little more specific.. Which of the box dimensions are the L W and H? And is the port 6" deep or wide? You said 102sq in, but that would mean 17 tall, 6 wide and 17.25 deep...
Be descriptive about which numbers are which. Ppl write them in different orders sometimes.
If your inner box dimensions are 37.5 long x 23.25 wide x 17.75 deep and your port is 17 tall x 6 wide x 17.25 deep with 102 sq in like you said, I'm getting a little under 8 cu net with a little over 36hZ tune. It's done by hand so I might have fudged a number or two.
But that's only if your dimensions are as I stated. I'm still confused about your number placement.
Need an install? Hit me up.
[email protected]
i used BBP and got 8cuft, and 7cuft after port displacement. tuned to 40.26hz. i did the port as 17"W x 17.25"D x 6"H
im getting that it should be 27 inches long for that big of a port. from WinISD
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
where is the port located? is it horizontal somewhere?
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
also, got 7.69 gross before any displacement
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
Like I said. The numbers are out of order so everybody is making different assumptions and getting different numbers. My hand work is not wrong, it's just plugged in differently.
[email protected]
wasn't diagreeing, just stating what i found. seems like the port is far too short to be at 34 hz imo. but winisd could possibly be wrong? port placement is going to differ the final net volume as well with how many sides it has.
Want:
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
Have:
  • Who's Online   0 Members, 0 Anonymous, 6362 Guests (See full list)
