I got a 09 impala and im plannin on puttin a double din in it,but i had a couple ?'s.First one is how do i take off the surround around the radio.Second i wanted to know if there as a something for me to hook upi so that i can still use the controls on my steering wheel. last but not least i wanted to know if i could still use my factory amplifier with and after market radio?
Im sure the plastic around the radio pops right out but not sure! you cant use the steering wheel controls with aftermarket radios unless u have a special connection witch you would have to buy in order to keep them usefull, and the factory amp, will still work juts make sure u hook up all the wires on the cd player harness. good luck
Right on my dude i appreciate the advice.
i'm assuming you have a gmos or equivalent harness to install it (metra is down, i cant rele check which one is right, you're prob able to get away with an xsvi harness)
if you get a metra or scoche dash kit, it should come with instructions on how to install everything, unless its a generic kit
as far as steering wheel controls, check peripheral and axxess, its more so reliant on the headunit you're putting in than anything, and its generally a pita to get working, make sure your headunit is "wired remote capable" or soemthing along those lines, or you're SOL
some that you would think would do it, just dont (like pioneer's flagship avic-f90...1200$msrp nav that cant even have steering wheel controls
Team DC
The radio is a Kenwood Excelon Kvt-717dvd as of right now but i do think i will be upgrading to a pioneer of some sort just which ever i want. I went with this one because i have it already and it has a higher pre-out voltage for a clean signal.
You said a double din but the kvt series is a single din. The dnx is a double din. But all the pioneers i have used have a bad rca grounding issue after awhile. If u use the kenwood you can get the steering wheel control moduale for it and the harness is a data harness that works with the factory amp.
94 lincoln mark viii
h/u: kenwood kvt 614 Excelon
comps: alpine type x
amps: mtx 1501d mtx 4004
sub:2 DC lv4 12
wiring jl audio 0awg 8 awg sub
jl audio 4 awg for mid and highs amp
myspace.com/kylecm85
carstereolexington.com
Yea u right but the only reason im puttin that in is cause i already had it but ive been looking for a double din because it just looks cleaner to me.
  • Who's Online   1 Member, 0 Anonymous, 1151 Guests (See full list)
