ok im running three amps now and i have never done it before just one amp at a time but my queston is the remote wire on the deck is going to my exzisting amp in the back can i jump from that amp to anuther then from that amp to the last one with no issues any help please
yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remote
it gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks uhoh im would like to do that so when you dont wont all the bass you can just turn um off
also helps if you need to cut your system off say cops or somthing and your beatin your music you have a quick kill switch
R.I.P!
(Nov-29-2009)
92 explorer
current build
[yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remote
it gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off ]
yeah i have the same thing, i have a switch right at the kick panel under the foot e-brake.....just incase i cant turn the volume down when i see cops.
3 is about the limit I would hook up to a single headunit's remote. You don't wanna pull too much current through that little wire and bake your headunit's remote circuit :o
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 3394 Guests (See full list)
