Amp Remote Wire
fast85_gt
yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remote
it gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks uhoh im would like to do that so when you dont wont all the bass you can just turn um off
also helps if you need to cut your system off say cops or somthing and your beatin your music you have a quick kill switch
R.I.P!
(Nov-29-2009)
92 explorer
current build
[yeah it works, have my 2 sub amps running off a toggle switch and my mids/high amp off the decks remote
it gives you more control if say your driving to work in the morning and dont wanna have your subs going you can just turn them off ]
yeah i have the same thing, i have a switch right at the kick panel under the foot e-brake.....just incase i cant turn the volume down when i see cops.
  • Who's Online   0 Members, 0 Anonymous, 1043 Guests (See full list)
