raytard Posted January 27, 2009 Report Posted January 27, 2009 personally, ive had 4 pioneer decks so far (the old 5900, a 690, a 600, and now an f90), and have grounded the rca's on every one. ive used the little chrome screw that holds the rca's to chassis, its worked very well every time, and usually holds better than wrapping it around the rca's, i always manage to knock those off one way or another. Quote Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
Texas Tech Posted January 28, 2009 Report Posted January 28, 2009 Does this only happen if you have your speakers off an amp. So there wouldnt be noise if you ran the speakers off the deck? Quote Baylor University Accounting
uhoh_45 Posted January 28, 2009 Report Posted January 28, 2009 I can honestly say Ive never seen that done before. Worth a shot. search google images for rca ground, or pioneer rca ground Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
