personally, ive had 4 pioneer decks so far (the old 5900, a 690, a 600, and now an f90), and have grounded the rca's on every one.
ive used the little chrome screw that holds the rca's to chassis, its worked very well every time, and usually holds better than wrapping it around the rca's, i always manage to knock those off one way or another.
Team DC
Does this only happen if you have your speakers off an amp. So there wouldnt be noise if you ran the speakers off the deck?
Baylor University
Accounting
I can honestly say Ive never seen that done before. Worth a shot.
search google images for rca ground, or pioneer rca ground
R.I.P!
(Nov-29-2009)
92 explorer
current build
