High Output Alternators
I have a stock 80 amp alternator in my toyota corolla. I currently have 2600 watts rms going through 2 batteries. I was wondering when is it time for a high output alternator.
It's over 9000!!!
ummm let me see .....
when your lights dim badly
when your voltage drops way below 12ish
when your car cuts off because it can't keep up
there's more but too much typing. my true way of knowing is when i'm baning in the parking lot, lights are dimming and voltage is dropping like crazy. upgrading is always better for your batteries, amp and such.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Thanks man I should get a voltmeter.
It's over 9000!!!
Guest KyleCannon
Personally man, with an 80 amp alt, you need to upgrade regardless, your batteries probably never see full charges anymore. I was in that position, had an 80 amp alt with a D2400 Powermaster and when I came home, hooked it up to the intellicharger and it took 3 hours to charge. That was also after I got the 300 amp alt and drove home 60 miles, it was still that dead.....
If your voltage drops below your alternator's normal loaded output (probably 14v or higher) then the alt isn't keeping up with the load.
If it drops below ~12.8v then your alt and batts combined aren't keeping up with the load.
10.x volts fo' life!
  • Who's Online   0 Members, 0 Anonymous, 964 Guests (See full list)
