whats the height of the port
5.75" I belive
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
post the dimensions of box and port
2 18's Fi SSD All Options Dual 2 ohm
Rockford Fosgate T20001 Bd
1/0 gauge Knukonceptz power wire
Pioneer Touch Screen Navigation AVIC F700
13.62 cu ft box ..28 hz
250 amp alternator
2 kinetik 2000 batteries
Xs Vcm Module
if made the length and width opposite then you should have a bit of a lower tuning.
only solution to make it higher is cut the porth length or make the port bigger
Dimensions are:
44" width
27" depth
17" height
port:
top part of port (part i messed up with):
20.5" length
22" width
(thats what it is supposed to be)
side port walls:
5.75" height
25.5" width
Port opening, 22" x 5"
I have to get off for an hour so I'll check back when I come back.
I can post the designs if you don't get those specs, I didn't at first.
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Dimensions are:
44" width
27" depth
17" height
port:
20.5" length
22" width
side port walls:
5.75" height
25.5" width
ok so ur box is 9.34 cu.ft..and to tune it to 33 hz make the length going in the box 18 inches and you will have 33hz
250 amp alternator
Xs Vcm Module
wait what? It is supposed to be 7 cu.ft....
doing it by hand, I get 11.6875 cu.ft, so after port and sub displacements you got about 9 cubic feet?
Btw, the length going in the box as of right now is 22", so what would that make the tuning? Sorry, I know everyone asks that question, but I know I'll mess it up.
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
the port side in the box what is the dimensions of the opening
250 amp alternator
Xs Vcm Module
i use a online calculator to ffigure the volume out
250 amp alternator
Xs Vcm Module
Well, it is 20.5" by 5.75". It meets up with the front wall, then it spreads to 22" by 5". That only makes it like 3/4 of an inch opening at the very end. If you look at my pics you'll see what I'm saying.
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
my mistake i was entering the wrong numbers it is already tuned to 33hz ...my bad
250 amp alternator
Xs Vcm Module
