knowledge Posted January 29, 2009 Report Posted January 29, 2009 ok guys, so i have the alpine iva-d105 everything is installed in my car and it works great, the problem that i have is that when i turn on my car the screen on the indash comes out and is blank but to visually see something on the screen i have to manually turn on the radio by pressing a botton, (why is that?) when i turn off my car the radio turns off but the screen stays out????????also the memory is not working??? thanks guys.... REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
bigjoe Posted January 29, 2009 Report Posted January 29, 2009 i have had a friend with that same problem. check your wireing. he changed the wires and and re wired them and it worked out better.
bennett15 Posted January 29, 2009 Report Posted January 29, 2009 i have an flip out panasonic and i have a setting called acc that sends power to the deck and turns it on other wise i have the blank screen thing soon as key is turned. also look in settings or something for somehting that says manual or auto to slide in and slide out when started and turned engine off im pretty sure that should have it mine does 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
jmsonoma03 Posted January 29, 2009 Report Posted January 29, 2009 sounds like you have the constant and ignition backwards or both on ignition.
limited187 Posted January 29, 2009 Report Posted January 29, 2009 ok guys, so i have the alpine iva-d105 everything is installed in my car and it works great, the problem that i have is that when i turn on my car the screen on the indash comes out and is blank but to visually see something on the screen i have to manually turn on the radio by pressing a botton, (why is that?) when i turn off my car the radio turns off but the screen stays out????????also the memory is not working???thanks guys.... Trust me go and change your ground and need better 12v source that will fix it same problem to my girls car and i fixed it ALPINE IVA-S106 AUDIO CONTROL EPIC CENTER Jl Audio 1000.1 (4) Jl Audio 300/4 (2) MTX 9500 (4) 15" MTX TXC ( 6.5" 260 IRRAGI ALT BIG 3 Los Angeles – The gang capital of the world
jmitch Posted January 29, 2009 Report Posted January 29, 2009 sounds like you have the constant and ignition backwards or both on ignition. Trust me go and change your ground and need better 12v source that will fix it same problem to my girls car and i fixed it both of those will work try the 1st 1 1st its easier and faster!! I know a lil about everything so dont call me Mr. Know it All.
knowledge Posted January 29, 2009 Author Report Posted January 29, 2009 sounds like you have the constant and ignition backwards or both on ignition. how can i fix that problem i have no idea?????? plus i just switch my old radio for this one and my old radio worked fine so i have no idea???? REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
NomaOnAir Posted January 29, 2009 Report Posted January 29, 2009 how can i fix that problem i have no idea?????? plus i just switch my old radio for this one and my old radio worked fine so i have no idea???? Well for starts did you splice the wires or did you use a clip ? The yellow wire is your constant 12v and the red is you acc wire .. (incase you didnt know) Also if you spliced the wires here is wiring chart of whats , what. Constant 12V+ Blue/White Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Driver's Pillar Front Speakers 6 1/2" Doors Left Front (+) Blue Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6" x 9" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rea r (+) Red/Yellow Right Rear (-) Brown/White also Im not sure about your model flip out , but could it possibly have something to do with the ebrake switch ? just an idea.
knowledge Posted January 30, 2009 Author Report Posted January 30, 2009 i rewired everything and is still doing the same thing. also i spliced all the wires and for the video im using one of them video bypass things they sell on ebay, and the memory aint working so im going to double check everything so i thank all of you that are helping, and if there is anything else that i need to know let me know. thanks guys. REFF'SMy linkEBAYhttp://feedback.ebay...ck&myworld=trueI love car audio so much because I will never be done. I can never win, and I will never get it finished or perfect. It always has me coming back for more, I can never get my fill of it, but I get what I need.
