ok guys, so i have the alpine iva-d105 everything is installed in my car and it works great, the problem that i have is that when i turn on my car the screen on the indash comes out and is blank but to visually see something on the screen i have to manually turn on the radio by pressing a botton, (why is that?) when i turn off my car the radio turns off but the screen stays out????????also the memory is not working???
thanks guys....
REFF'S
My link
EBAY
i have an flip out panasonic and i have a setting called acc
that sends power to the deck and turns it on other wise i have the blank screen thing
soon as key is turned. also look in settings or something for somehting that says manual or auto to slide in and slide out when started and turned engine off im pretty sure that should have it mine does
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
thanks guys....
Trust me go and change your ground and need better 12v source that will fix it same problem to my girls car and i fixed it
ALPINE IVA-S106
AUDIO CONTROL EPIC CENTER
Jl Audio 1000.1 (4)
Jl Audio 300/4 (2)
MTX 9500 (4) 15"
MTX TXC (8) 6.5"
260 IRRAGI ALT
BIG 3
Los Angeles – The gang capital of the world
sounds like you have the constant and ignition backwards or both on ignition.
both of those will work try the 1st 1 1st its easier and faster!!
I know a lil about everything so dont call me Mr. Know it All.
how can i fix that problem i have no idea??????
plus i just switch my old radio for this one and my old radio worked fine so i have no idea????
REFF'S
My link
EBAY
Well for starts did you splice the wires or did you use a clip ?
The yellow wire is your constant 12v and the red is you acc wire .. (incase you didnt know)
Also if you spliced the wires here is wiring chart of whats , what.
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Driver's Pillar
Front Speakers 6 1/2" Doors
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rea r (+) Red/Yellow
Right Rear (-) Brown/White
also Im not sure about your model flip out , but could it possibly have something to do with the ebrake switch ? just an idea.
i rewired everything and is still doing the same thing. also i spliced all the wires and for the video im using one of them video bypass things they sell on ebay, and the memory aint working so im going to double check everything so i thank all of you that are helping, and if there is anything else that i need to know let me know. thanks guys.
REFF'S
My link
EBAY
  • Who's Online   1 Member, 0 Anonymous, 1583 Guests (See full list)
