how does that T10001bd compare to the hifonics 1500d that you had in there?
I can tell it puts out a better, cleaner sound!!! It also seems alittle more powerful, but not much more. It didn't come with a birthsheet so I don't know how much power it puts out but I'm thinking 1500+rms.
Thinking about selling my T10001bd and getting a T20001bd cause I really don't want to run 2 sub amps, never have before!!!
AudioControl
Rockford Fosgate
XSPower
a9cb521a-b3b0-4848-8950-41c45879dd3f_zps
yeh i was thinking the same with my two 1500ds .......... i'd rather just have one big amp. besides i'm only playing each 1500d at 2 ohm each. i still wouldn't mind running a pair of T10001bds in master/slave mode though. but one big amp will always outdo two small ones (depending).
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Lookin good man. What size box & port are you using? Tuning? Does it pick up the lows in the 30-32hz range well? I'd defintely like to see some more vids.
The box is 12ft^3 after braces and all, tuned to 30hz. 123.5in^2 port. And yeah it hits the lows VEEERRRY well!! I'm going to get some vids soon as I get every thing finished. Still got to get my other amp, either another T10001bd or sell the one I got and get a T20001bd. I need to make my dog gone mind up!!! :lol:
AudioControl
Rockford Fosgate
XSPower
i say it depends on whether your subs are d2s or d4s. if you have the d2's i'd stick with the T1ks and run them each at 1 ohm and if you have the d4s run them at 2 ohm each and bridge them to 1 ohm. i'm sure you want them to get the most power possible right?
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Changing those bx1500d to T10001bd would sound alot better, believe me!!! Some guys told me that running 2 smaller amps at 1.4 ohms is better on your electrical sys than running one big amp at 0.7 ohms. I don't know if that's true but that's one reason why I chose the T10001bd.
AudioControl
Rockford Fosgate
XSPower
well your reasons for choosing the T10001bd(s) are good then. i say get another one and call it quits bro. no need to get the T20001bd and run it at 0.7 and risk malfunctioning problems ya know. i had a deal on some T10001bds (could have gotten them brand new for around $200 each). i passed on them because I was trying to cop the T20001bd (which was i could have gotten for $300) but because they couldn't get any T2ks in i opted to by my hifonics 1500ds, only to realize heck i should have picked the T1ks up anyway cause they were pushing same as the 1500d but i knew for a fact they had real power behind them and were underrated vs overrated. that was a year and a half ago, can't get a deal like that now a days.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
My subs are d1s and I have them series so each T10001 will see 1.4ohms. Right now I've got both subs hooked up to the one I have @ .7ohms. I tried this before when I first got the amp and it would go into protect mode. Since I put the 2nd batt in it's been running fine. I also just hooked 1 sub up @ 1.4om and it hits as hard as having both of em' hooked up, so I do need more power. These Qs are AWESOME!!!
AudioControl
Rockford Fosgate
XSPower
Man I would have JUMPED on that deal!!! I think I'm going to stick with the T10001bds. Knowing me I'll end upgrading my subs soon, so having 2 powerful amps will make it easier. I got my T10001bd from HDA. Refurb for $360 with 2 year warranty. Going to get the other one from them also.
AudioControl
Rockford Fosgate
XSPower
Since your running dual 1ohm subs I'd stick with a single amp setup and go with the T2K. Running a pair of T1Ks, the amps will see closer to 2ohms and you won't get full power out of them.
  • Who's Online   0 Members, 0 Anonymous, 541 Guests (See full list)
