Menace89's 06 Sonata Build
Didnt takes pics of it but i did a total of 3 layer of body filler then went on to paint
Posted Image
Posted Image
Paint
Posted Image
Posted Image
Flexstone
Posted Image
Posted Image
Then i decided to take the small decal i got and put it on the rear window
It worked out great since theres a little spot in the defroster lines where it fit
Posted Image
Posted Image
its stuck on from the inside....very stealthy B)
Very cool, you're givin me a lot of ideas for a box I'd like to build someday, very professional.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
So i decided that i wanted brushed aluminum on the bottom instead of mirror cuz i figured it'll be easier to cut out the shape of the divider out of aluminum than mirror....
soooo, i went and got a piece of aluminum, sanding block, and some 60 grit sand paper
Posted Image
and with a little elbow grease it starts lookin like this
Posted Image
Posted Image
and after a few hours of sanding and a couple of clear coats its done
Posted Image
Posted Image
Since the clear coat chipped from cutting it I decided to re-brush the aluminum to make it look better
Posted Image
Posted Image
Posted Image
then i ran into a little road block...when i put the second set of LEDs on i set the back in place and turned em on to find out that they were a different color :censored:
The first set was dark blue and the second set was kinda turquoise but it made the right side of the box look green...sooo i had to order a new set of LEDs
Posted Image
Posted Image
Posted Image
it looks good in the pic but trust me it was green and it looked horrible
  • Who's Online   1 Member, 0 Anonymous, 1355 Guests (See full list)
