Battery in Front, Battery in Back, 1 Amp
Is it 18" from front batt to trunk bat, then rear batt to amp?
Or 18" from front batt to trunk batt, And on the same wire 18" from rear batt, and then 1 from rear batt to amp?
So 2 or 3 fuses?
So 2 or 3 fuses?
:01nocomment8so:
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
Guest KyleCannon
I would say 2 fuses. 18 inches max to the batteries. If you want to protect your amps further, fuse by the amps as well.
Edited by KyleCannon
thanks thats what i thought, but one of my friends got me ?ing myself. thanks
well if it is that dumb of a ? then you could easily answer it instead of being a dick?
X2
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
You want one fuse 16" or closer away from the front battery on the Positive line. Then you want another on the rear battery at most 16" away from the rear battery. So when you get through, you should have two fuses on the same cable each very close to its own battery. Then if your amp is not internally fused, wire another b/t the rear battery & the amp.
Edited by c0smo kram3r
I have the RF t-1000-1 It has a built in 100 amp fuse, so does that mean that i dont have to fuse it to the rear battery?
Guest KyleCannon
No, if you don't fuse the battery and it shorts the battery can explode. The amp fuse would only protect the amp.
  • Who's Online   0 Members, 0 Anonymous, 2560 Guests (See full list)
