Bad Preout Question...
Is it possible for ALL of the preouts to suddenly go bad?
Everything was fine in my last install and not a month later, as soon as I hook everything up, there's a screaming hiss AND alternator whine coming from the speakers, and a low rumble coming from the subs. Even with the car off! (No whine when the car's off, but the hiss is still going).
I didn't think much of it at first. I tried two other four channels and they all did the same thing. I tried two completely different sets of RCAs inside and outside the car and it continues.
I've ruled out everything but the head unit now, so I wonder... It's not grounds because I have negative runs from under the hood and the amps are grounded to the battery bank on separate batteries. So basically all of the RCAs have random voltage going through them to cause the hiss and not even a month ago it was clean as a whistle.
Any ideas? I'm not even sure if it's in the right section.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
Got car audio questions? Check here first!
Everything you need to know. =]
http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
im not too positive on this but ill give it a shot since your looking for a hand/ ideas :unknw:
the RCA pre-outs might have went bad. mine did the samething. one day it was fine, the next, FUZZ!
i fixed it by grounding out the RCA's. dont remember exactly how i did it since it was so long ago. pioneer HU are known for that shit.
chime in if im wrong guys, good luck!
It's actually a Panasonic...maybe I'll try doing that but I think I'm gonna get rid of this HU soon and go with a better one.
I'll let you know how it goes.
[email protected]
check your speaker wire if it got pinched by something. that happened to me before and it was the culprit
Well I forgot to mention that I tried a speaker out back with direct hook up and it does the same thing. I got the rumble of the subs to stop by messing with the RCAs on the line driver, but the hissing it still going. I'm pretty sure the preouts went bad because I've tried everything now except a different source.
Unless someone has any other opinions?
[email protected]
try a different source for kicks and giggles, a 3.5mini jack to rca cable if you have one, and hook it to an ipod and see what happens. (both directly to the amp, and from the rca's behind the radio, just to narrow it down to definately being the h/u)
some companies diode isolate the rca ground to chassis for some strange retarded ass reason, and if something happens like you pull rca's while power is connected and the prong touches ground, poof, no more rca ground (pioneer is notorious for it, iirc panasonic did it too on some of their h/u's, screens mostly)
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
My pioneer had similar problems. The subs would rumble, noise through the speakers. I got a new alpine 9886 and its gone, however, there is still a little noise through the speakers (engine noise), im going to get better grounds and new RCAs and see if it helps.
I never tried grounding the RCAs like many people on this fourm have, did you try that yet?
Baylor University
Accounting
  • Who's Online   1 Member, 0 Anonymous, 726 Guests (See full list)
