F N LO Posted February 3, 2007 Report Posted February 3, 2007 hey, alright i have a clarion 1000.1 mono block amp, it has an automatic switch internally to change from a 4 ohm load to a 2 ohm load... when i wire my SVC 4ohm subs in parralel, the amp cuts out alot earlier then it should, however if i wire them in series (8ohm load) then it works, and the subs are loud... so my question is, should i be running my subs at a 8 ohm load with the amp running at 4ohms... or should i just run it in parraell(2ohm) and just have my subs noty as loud as possible.... i think the switch for the load has been swtch so many times it is either stuck in 4 ohms, or just doesnt know the difference... can anyone help me???
dmanson Posted February 4, 2007 Report Posted February 4, 2007 take that amp back to the store of call up a clarion tech 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
F N LO Posted February 4, 2007 Author Report Posted February 4, 2007 ok i got it fixed, i dont know how or why, but this time when i hooked it up in parralell it doesnt cut out until its oober turned up...so yea i think i got it figured out...i got vereything at 2 ohms... so far so good, and my new box sounds LOUD!!!(for 2 clarion tens that is...)
ChevyBoy Posted February 5, 2007 Report Posted February 5, 2007 i dont get what youre saying. 2 svc 4 ohm subs wired in parallel make it 2 ohms. you said your amp will take it from 4 ohm to 2 ohm, which in turn means you amp will take it from 2 ohm to 1 ohm. if thats right, thats why your amp is shutting off.
F N LO Posted February 5, 2007 Author Report Posted February 5, 2007 ^^^ is that a common thing in amps?? because i was told it will automatically adjust its output to match the wiring, wether it be 4 or 2... but what you said makes alot of sense if it is a common thing with amps...
ChevyBoy Posted February 5, 2007 Report Posted February 5, 2007 no its not a common thing. some mtx amps have them, mine did, and i guess clarion? im not up-to-date on clarion so idk about them.
F N LO Posted February 5, 2007 Author Report Posted February 5, 2007 alright well i will do some digging, and let you know what i find :detective2:
