Kryptonitewhite's Pics And Vids Build Log Fi Ib3 18" And 22"
We shopped for a Buick Rendezvous or Pontiac Aztac so we could get >18 cubes and still have room for kids, grocieries and such and avoid getting a minivan. Explorers, Blasers, Bravadas, and the like we'ren't nearly enough.
Basically we are walling the hatchback. >20 cubes, 8" port. This is temporary until a 21" or 22" driver of similar specs is finished. ( >30mm Xmax, <20Hz Fs)
I originally designed it to have the sub on top and port on bottom, but once the 22" is in, side by side works better.
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
IB3 22"
so your getting a 21"-22" sub custom built?
or looking on the market for one?
thays a lot of stuff u want to stick in there
using the IB sub in a wall
isnt that a no no?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Scott of Fi is working on the IB3 22" that is supposed to have the same Vd as two IB3 18's http://www.stevemeadedesigns.com/board/public/style_emoticons/default/hairtrick.gif
He's also doing an auto version more suited for in-car.
Kevin Haskins of Exodus Audio is working on a 21" Maelstrom-X to get by until he can get costs down to do the 21" Sicko, implementing the Parthenon motor and a 4" 4000 RMS coil :D
IB3 22"
Thats why we were looking for the minivan sized SUV's... the exploder, blaser, and bravada's weren't nearly large enough, but significantly cheaper and gas guzzlers. 3.4 L engine, but they still get up and go... well, before 6-60lb batteries, a 22", all those amps and that wood....
IB3 22"
isnt that a no no?
well, I prefer to call it a sub with 30mm Xmax and 22Hz Fs, just right for my tastes.... but even if I put it in there "IB" it wouldn't be, IB requires a minimum of 10 times the Vas of each driver on each side, the IB3 18's Vas is 13.7 cubes... so i'd need a minimum of 137 cubes on each side of it....
these might be redundant, but they go in this thread anyway:
a little aqward :P
free air 16Hz or 20Hz
bass i love you free air aprox 4.5 - 18 watts according to DMM... demo just to show 7Hz signal is lowest, not 18Hz in that track
DMM showing 5.7 volts during 7Hz tone, 6x6=36 watts/2 ohm= 18 watts
no more than 12 watts DMM
IB3 22"
