Megalo's Maniac Stealth Sq Build
Posted Image
i think he might be referring to this pic, looks kinda like a cardboard box taped up
Too bad for him it isnt... n00b-comments...
all made from birch
Posted Image
before the dustcap was replaced
Posted Image
Posted Image
Posted Image
Team Stereo Clarity
from what i remember running actives allowing all frequency's play through the sub (please correct me if i'm wrong) but i've never heard that before in person and was wondering how it sounds with the higher hz going threw the sub (hope this makes sense)
R.I.P!
(Nov-29-2009)
92 explorer
current build
no, it means I am not using passive crossovers(the little box that goes inline with your speakerwire to your comps) after the amp, all signals are crossed before the speaker outputs of the amp. For instance if you use the xover on your amp, its considered going active. However in my case I have them crossed before it leaves my deck, still considered active.
Team Stereo Clarity
active means that the sound is crossed over without the use of a passive crossover (those ones that come with a normal set of components)
you're thinking of through pass/no filter
Team DC
thanks for clearing that up
R.I.P!
(Nov-29-2009)
92 explorer
current build
where's the horns? did u give up on them?
I couldnt get my stage to lift past my dash line, also required too much tuning time to get them to sound "okay" for starters even then I tonally wasnt happy the way they sounded. I played with some B&G neo3 planars and I really loved the way they sounded but they have to be onaxis to sound good, and I was losing way too much depth using them, unless I used them in the kick but the trade off of that is a lower stage. I had to make sacrifice one way or the other if I didnt want to do heavy modifications.
Team Stereo Clarity
I did buy myself an RTA setup, my intention when I bought this was for home use, I might use it in the car for giggles just to see my response to fix any spikes.
Posted Image
Posted Image
Team Stereo Clarity
