Stinger 1700 Help
my friend gave me a stinger 1700 batterie he said his charger kicked out while charging it he guessed it was shot so i brought it home and charged it over night charger did not kick out after it sat on the charger for a couple hours i unhooked the leads and left them off a few hours and checked volts with a dmm it was still sitting at 13.1 volts do you think it would be safe to uus in my appcation or shoul i take it and have it checked by the pros at autozone anyone plz
Hell just stick it in as a starter battery for acouple days and see how it reacts.
On the first run though, make it a short trip around the block. (I learned that the hard way. Don't get to far from home) Then pull into the driveway turn it off and start it and drive it for awhile and then park it till the next day.
If your altenator starts to squil or squeal with it hooked up for more the 30 seconds to a minute, I would say its shot man.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I just shit myself from laughter.
worse case is to let it sit longer and change the voltage.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
ok ill check it tommorrow and see what it does
there you go.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 648 Guests (See full list)
