Battery Help
i need to know how to wire 2 batteries in the back of my car they can only fit in each corner of the car i know from front to back is + to+ and -to- then wire the back 2 together + to+ and-to- but what one do i need to power my amps off of does it matter
not to be a butthole but look down at some of the other topics, i think this how been discussed multiple times this week alone.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Battery under the hood: (+)--[FUSE]------------------------[FUSE]--(+) to one battery.
From that one back battery, (+)--[FUSE]----------------------[FUSE]--(+) to other back battery.
(If your batteries were closer, you would not have to fuse them but b/c they are on opposite sides, you do.)
Now, this is how I plan to wire mine... I think this is right, but someone else could help w/ it probably. I didn't know whether or not to ground the back batts or not.
this looks like something i had in minh thanks for you help
