rookie023 Posted February 7, 2009 Report Posted February 7, 2009 quick question... 6 d4 subs. 2 amps. 3 d4's = 2.67 ohms. i was looking at amps.. say i find a 4000 watt amp that pushes 4000x1@2ohms is that going to push 4000 watts at 2.67 ohms? i dont know exactly how that works since there is a decimal and all that stuff. just looking for a little help so i know what to look for while im looking for amps. thanx -Jeremy edit: the12volt.com says stable at 2 or 1 ohm but like i said i want to get a amp that will be able to use its rated power correct? i dunno just help please 2002 Chevrolet Tahoe 4 Kicker CVX 12's (under construction)
dmanson Posted February 7, 2009 Report Posted February 7, 2009 quick question...6 d4 subs. 2 amps. 3 d4's = 2.67 ohms. i was looking at amps.. say i find a 4000 watt amp that pushes 4000x1@2ohms is that going to push 4000 watts at 2.67 ohms? i dont know exactly how that works since there is a decimal and all that stuff. just looking for a little help so i know what to look for while im looking for amps. thanx -Jeremy you might get a lil least than 4000 at 2.67 and then you have to factor in your voltage drop. get a good alternator or two, MLA module, a couple runs of 1/0 and a couple (or more) good batteries to keep that voltage up and you'll be okay. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
rookie023 Posted February 7, 2009 Author Report Posted February 7, 2009 you might get a lil least than 4000 at 2.67 and then you have to factor in your voltage drop. get a good alternator or two, MLA module, a couple runs of 1/0 and a couple (or more) good batteries to keep that voltage up and you'll be okay. awesome. im looking at a mechman alt and a dual bracket. im just trying to find good amps 2002 Chevrolet Tahoe 4 Kicker CVX 12's (under construction)
dmanson Posted February 7, 2009 Report Posted February 7, 2009 well that depends on how much you want to spend. kicker and audiopipe has good amps that do a good final 2 ohm load. there's others but that's to name a couple. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
Guest digitalboy Posted February 8, 2009 Report Posted February 8, 2009 Remember, a sub may say 4 ohm. But can be 3.5-4.4 ohm. They are rarely right on the mark.
Boon Posted February 8, 2009 Report Posted February 8, 2009 At 2.67 ohms you'll get between 1/3 and 1/4 less power than at 2 ohms. You're better off getting 2 1 ohm amps and strapping them so they see 1.33 ohms each. 10.x volts fo' life!
