IAMBUMP Posted February 8, 2009 Report Posted February 8, 2009 I've got a few good re8's and one that seems to push too much at times. I'm not sure which one it is, and i'm not sure why it does what it does. Is there a general rule behind this happening? It was in a box of 4, and only one did it...Could it have just been wired wrong, in both setups? If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
Clif Posted February 8, 2009 Report Posted February 8, 2009 i would guess that one could of been wired wrong. is it in a sealed or vented enclosure? 03 Trailblazer EXT LT In Dash Rear Flip Down Polk Audio Font & Rear Stage Hifonics Zeus 4 Chan Amp Hifonics Brutus Mono Amp 12" Rockford Fosgate Power HX2 T-Line tuned to 45hz 18"BTL T-line @31Hz (9 weeks pregnant)
IAMBUMP Posted February 8, 2009 Author Report Posted February 8, 2009 i would guess that one could of been wired wrong. is it in a sealed or vented enclosure? it was ported, and ported correctly. i just dont want to build the box and the one stil be crap. then again i never did try and check polarity. no clues. If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
creyc Posted February 8, 2009 Report Posted February 8, 2009 Could one have been wired in parallel while the rest were in series? That would cause one to pull much more power. There could also be a tear in its surround/soft parts causing it to "free air" basically. Same would hold true with a leaky gasket, although if its shared airspace all subs will be affected. Check the coils with a meter, make sure they all read the same, and that it's wired the same as the others. 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
IAMBUMP Posted February 8, 2009 Author Report Posted February 8, 2009 the subs are no in a box or anything anymore, i took it out of my old truck and saved em for a future setup. is there anything i can do with them with no power or anything to check them? how can i check to see if they are backwards in polarity with a dmm. If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
