Finding Accessory Power
Where would I find some accessory power in the engine compartment?
Some people say look in the fuse box but where?
-Kasey
Wouldnt be thehoe92 without teh purple
-Kasey
normally the fuse box is inside the car, well, older cars anyway, not sure about newer ones
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
the tahoe has two if I am not mistaken.
one right by the driver door behind a panel and one in the engine compartment.
look at the right of this picture.
ps this isn't my car I just didn't have a picture that showed the fuse box.
most fuse panels under the hood are b+ constant and the inside under dash fuses are acc and ignition. you could always just run a wire inside
ah I get it.
alright that sounds like thats going to be my solution then.
thanks for the help fellas.
ah I get it.
Not sure if you deff found your solution yet or not, but whenever im looking for an acc wire, I usually run a wire and connect it to the radio fuse under the dash, that way its fused and turns off when you want it to.
Anytime I need and ignition or an accessory wire, I go strait to my ignition colum.
You should have everything you need rite there in one spot.
Find your ACC wire and splice into it.
Don't worry its safe. Thats were most of the after market remote startes get spliced in at. So nothing to worry about.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
