doubleD Posted February 10, 2009 Report Posted February 10, 2009 im getting a treo cxt 4.1 built. and want to know if any one has used these amps.this amp is supposed to do 4400 watts @ 1 ohm in the 11 to 14 volt range. and @ 1\8 ohm around 6000+ watts...and even more if you up the voltage
Boon Posted February 10, 2009 Report Posted February 10, 2009 2 things I doubt - 1. Power at 11v - It probably only makes proper power at 14v+ like most other big amps 2. 1/8 ohm - Will probably either protect or blow up. Might take 0.25 ohms on a rolled burp but it's risky. EDIT: I was thinking the 6.1 - I see you're getting the 4.1 Single 0 gauge power and ground, no way in hell it makes 6000w+ 4000w at a stretch at normal voltages. Probably more like 3000-3500w. 10.x volts fo' life!
creyc Posted February 11, 2009 Report Posted February 11, 2009 I think you're just a tad too optimistic in those numbers 2001 Chevy Blazer (2) SAZ-3000Ds (2) custom 18" Madmax subs in a second row wall Rockford 600-4 Pioneer PRS components Pioneer P800PRS deck
dwright27 Posted February 11, 2009 Report Posted February 11, 2009 idk the 1500 treos did over 3000 ..... treo makes nice stuff. and power @ 11 volts is possible. the RD medinas did 2300 @ 10.8 2006 F-150 4 DC XL M2 18's Walled Daily Driver XS Power 4 DC 3.5kw Team DC Team S.P.L. Lot of Audio Technix and 1/0 DC Audio Dealer American Bass Dealer XS Power Dealer Audio Technix Dealer
