T-line Help
uhoh_45
so a while ago i bought 4 ED 8" subs and havent done much of anything for them other then build a sealed box for buddys car well i was wondering if i could use the 4 of them in a T line
specs are
Power Handing : 100w
Available Voice Coils : Single 2 & Single 4
Sealed Box Size : .75-1.00cF
Vented Box Size : 1.25-1.65cF
Qts: .48
Qes: .64
Qms: 7.50
Fs: 32
Re: 4.1
Vas: 40 L
Bl: 6.8 T*m
SPL: 84.95 dB
Sd: 220 cm^2
Xmax: 6.00 mm
Voice Coil : 25 mm
R.I.P!
(Nov-29-2009)
92 explorer
current build
SPL or SQL? I would not rec. the SQL with these subs as you have a qts .48 and a qms of 7.5. Also do you care on the tunning? Do you have a eq or sound proc. or anything for a eq or boost? Also what kind of dimensions are you lookin at?
-Cliff
03 Trailblazer EXT LT
In Dash
Rear Flip Down
Polk Audio Font & Rear Stage
Hifonics Zeus 4 Chan Amp
Hifonics Brutus Mono Amp
12" Rockford Fosgate Power HX2
T-Line tuned to 45hz
18"BTL T-line @31Hz (9 weeks pregnant)
tuning would be 40 hz and im looking for sql not spl
i also have a 3 way xover/linedriver that has a 45hz boost
and max dimensions are
38 W X 31 H 48 D
R.I.P!
(Nov-29-2009)
92 explorer
current build
that they are and thats the reason i bought them but since then have bought some components and so these are in buddys car
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 549 Guests (See full list)
