A couple of days ago turned on my XBOX. Whast did I see? The dreaded ring of death. (Not again). I couldnt beleive it only this time instead of buying it at Costco I bought it at Game Stop. So I couldnt return it I was stuck. I went on You Tube and saw how to fix it with 8 pennies. What do I got to loose its garbage anyways so after about an hour following the the directions on fixing the problem came the moment of truth. I was shocked NO red lights it worked!!! Thank you You Tube.
ive gotten it on 3 systems the past 2 weeks... and a few cannot read disk errors... i dont see what the damn problem is with them..
Team Deadly Hertz
1997 GMC 1500
Update....
System is gone
Motor is fucked
Truck is down and out for a while
Myspace
YOUTUBE
My Build
i had the dreaded red ring o death about a month ago..got my box back about a week ago
NoFearX18 said:
trainman0978 said:
Those vids on YouTube are the real deal. Though I think it costs more then 8 cents. A few bucks at least. Mostly for the Arctic Silver 5 thermal paste. I bought a 360 a month after they launched (Dec. 05) and was able to keep it running until a month or two ago. I got the RROD just a year after I initially bought it. Searched around the net and found the fix that people are doing the videos on YouTube of. It works, no doubt.
If it's under warranty then get them to fix it. At the time mine initally died they didn't have the warranty they have now. So, it was either pay $150 or try and fix it myself. After you open the case your warranty is VOID. Kinda pissed me off they instituted that warranty after I had opened mine up. Oh, well. With the fix it lasted another 2 years.
Edited by dr hypothesis
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
(2) Fi BTL 18s (walled)
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
my dad and little brother fixed his, they also bought a fan that would be like in your computer case and cut a hole in the 360 case and mounted it so it stays cool, no more R O D
ONLY FIX IT URSELF WHEN UR OUT OF WARRANTY!!!!!
The total was 21$ and some change. Only because I had to buy the electric tape, the silicon glue, and the most expensive part the dam tool kit $15.99. But alot cheaper than a new Xbox for sure.
Tool kit must of been for the torx heads? Did you get the Arctic Silver 5 thermal paste? That stuff does wonders. The stuff Microsoft uses is junk and applied horribly.
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
