I was just wondering what is the best way to run speaker wire through MDF...drill a hole the same size as the wire and run it in, or use bolts to go through?
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
the best way that i was told is to drill the whole the same size as the wire and run it through and add some caulking or something to seal it.
that's what I thought...thnx :)
tsunami and stinger make 2 or 4 strand speaker lines encassed in a round jacket, a bit easier to use in an airtight situation than the conventional side by side wires
Team DC
ive always loved the look of bolts on the box.
Eclipse cd7000
I'm gonna be running the 8ga karma wire :)
actually, it may be better to use bolts for that wire, that shit is HUGE...lol
Edited by DHFHades
It a good idea to put a loose knot in the wire on the inside of the box at the hole and then silicone the hell out of it.
Edited by ISO
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
I think I'm gonna run bolts and wing nuts, that shit is as fat as a garden hose...lol
If your gonna run enough power that you need 8 guage speaker wire I very much recommend trying to get the wire from the amp to the sub in one piece.
Everything you put in line with something helps build up restince(can't spell).
I also feel its safer.
  • Who's Online   0 Members, 0 Anonymous, 546 Guests (See full list)
