I'm planning on putting my amp/wiring in soon, probably in about 3 weeks. I'm going to do the Big 3 and run 0 gauge. Anyone know how many ring terminals can fit on the one post? I already have the positive post, but was wondering if I can put all my terminals on one for the Big 3 negative.
Thanks for the insight.
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Full 1/0 Gauge Throughout
Big 3
You should be able too, and you can get the longer battery bolts at a local parts store for like 3 or 4 bucks
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
just didn't want to run into any problems when I go to install it.
Hope to get it done in one day, which seems reasonable.
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Big 3
if its side post u cant fit many ther its hard as hell to do it but on mine i used a longer bolt and a couple of nut and washers and i made mine fit that way until i founda peice of alum and made a hole to bolt to the batt and and other holes for the bolts to hold the wires.
I know a lil about everything so dont call me Mr. Know it All.
Whats up andy. just go get a side post extender http://www.sonicelectronix.com/item_6231_G...t+Terminal.html like this. i have them on my truck and you could prolly fit 3or 4 terminals in there.
get ahold of me when u decide to do your big 3. ill stop over and give you a hand if you want.
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
i usually have problems getting one like 8g thin copper ring on there
if you're doing multiple ones, or beefy 0g ones, get a longer bolt for sure
Monster sells a dual one, where its a stock length/size one for the car, and then another thicker post with nut past that that holds 1-5 lugs.
i like them, and its not like its super expensive, it may be a little fancy but whatever. just givin u some options.
Team DC
i had that one on my sonoma.. it could not even fit 2 kicker 1/0 terminals on it :( i got one from autozone and it can hold about 4
DC.jpgDC POWER
Ive got 3 0ga ring terminals on mine and one 4ga terminal so 4 total and i still have plenty of room. I bought my terminals from autozone
1997 2 Door Blazer
Bagged & Body Dropped
SBC/TH350
Sounds like I will go check out the ones at autozone, I was going to order the side post adapter from Darvex, same one I have right now, but sounds like the autozone one is a bit bigger.
Should I heat wrap any of the wire?
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Big 3
I'll deff have you come over to give me a hand, I plan on just taking a day off to get this all in. I'm just ordering all the small things before the amp now.
15" Fi BL
Ported 4.0 cu ft.
Sundown 1500d
Big 3
  • Who's Online   0 Members, 0 Anonymous, 2560 Guests (See full list)
