take a wire brush to the metal and make sure there is no paint where the terminal ring will go and make the ground as short as possible. anything over 12" is kinda long. other than that it'll work fine
i have did it like that for years and have never had a problem with it
thats not the ideal place for a ground...remember you want to maximize contact between your terminal and some metal :)
and theres not much surface area around seat belts...for smaller things id say ok but bigger amps no way...not to mention a ground can generate a lot of heat.
Edited by finkster
Eclipse cd7000
i to have used this method in the past,just wire brush to bare metal
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
sorry to thread jack crump, but my seatbelt bolt is attached directly to the floor of the car, bare metal. can i use that?
the strongest points of your body are seatbelt and brake pedal mounting location to which both are great places for a ground..just make sure the wire terminal is on top of the seatbelt mount
07 mote carlo..
thank you, now i need to go finish the install SON :spiteful:
  • Who's Online   0 Members, 0 Anonymous, 2516 Guests (See full list)
