Torres' Box Tuning Calculator - Updated 8/18
Torres
Sorry for being the idiot, I get it know I think, lol. The total of 22" refers to the physical port length and the angle to the walls of the box itself, I'm assuming this also has to be factored in. I believe I'm right, at least I'm hoping so, thanks
2011 Mitsubishi Outlander
Sony 712
Soundqubed HDS208
Alpine MRV-M500
Transmission line enclosure
Soundqubed wiring
Knu rca
XS Power battery
CNF terminals
i'm waiting on a couple parts to get my PC back up and running (don't want to install sketchup on this laptop, it's not mine) but if i can get it working, i can sketch what the port layout should look like. hopefully the pieces come soon. like yesterday
it only needs to be an L shape if the length of the port is longer than the depth of the box (or height, depending on port orientation). it doesn't necessarily have to be an L shape to get the tuning you need
for me to get tuning I want, port comes out to be longer then depth. So just make a bend so it will be same width everywhere?
correct! also make sure that in the end result, measuring down the middle of the port is the length that you entered into the calculator
  • 3 weeks later...
Hey torres! Love ur calculator! Quick question, i am doing a wedge shaped box, and when i put in height number 2 nothing changes. so to make sure im right i went to the 12 volt calculators regular square box calculator, put in the same dimensions besides the height number 2 and i got the same as ur calculator. so in other words ur calculator isnt taking into account the height number 2.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Ok tnx. Does the volume of the box change?
whatever your final net volume says in the calculator is what the net volume is, whether it does bend or not.
depth 2 must be higher than depth 1, and height 2 must be less than height 1. otherwise they won't be taken into effect. i think this may be why you're not getting a different volume. i may try to fix that so either number could be in either box, but may prove tricky when the numbers get assigned to the variables for the wedge shape volume block i have coded. that part was TOUGH getting accurate. the cut sheets would also need to be tweaked. could be for a later update *possibly*
just to kind of update the status of this, pretty sure all the major coding i wanted to do is FINALLY finished :) going to double check the way it prints, and then going to fix it so if you do wedge shaped boxes that the numbers don't have to go in certain boxes (such as how depth 2 must be higher than depth 1). i have the layout ready to code it, just gotta put the coding in the right parts. last minute thing i figured i'd change. it's 5 AM here now, so i'm going to bed
  • Who's Online   1 Member, 0 Anonymous, 1618 Guests (See full list)
