I have my btl, and I am borrowing my friends sub amp to listen to the sub because I can't afford an amp just yet. I am dying to hear it. It is wired at 1 ohm, but really .7 ohm (DMM). It says the amp is 1 ohm capable, but It goes into protect when I turn the amp on. What could be the problem, maybe its not 1 ohm capable? or the .7 ohm is too low?
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
is that with a signal or as soon as it turns on
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
with a signal
Think .7 and 1 ohm makes that big of a difference?
Please help! I just wanna hear this!!!
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Posted (edited)
update: I turned all the settings the other way, apparently I had the gain maxed out lol... I was confused and thought .2 was less than 6. I guess not though. Anyways, I got it to turn on and not go into protect while music was playing (car was off) So I turned the car on, and it didn't turn on. The big Crunch light didn't light up...
Why isn't this working?
could temperature be an issue? could my remote wire be messed up? the wire looked a little bad... maybe ill restrip it..
Edited by rumproast789
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
it shouldnt be getting hot if you're not playing it
try restripping the remote or replacing the wire completely
check ground also and rca
I will restrip the remote wire, and the ground is connected to the seat bolt. I don't think it was sanded down, but it worked when I had the amp in a long time ago just fine. I checked under the hood and I popped a fuse when I sparked tryign to connect the power wire lol.
I'll have to go get a new one, and I'll just retry it all.
Thanks man, I was getting hopeless that no one was helping
I'll post back if it works
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
jump the hot to the remote to see if it turns on still
What do you mean?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
What do you mean?
take a wire from your positive input on your amp and jump it to the remote turn on input.
91' Jeep Cherokee - The Heep
Just Empty Every Pocket
96' Volvo 960 - The B◘x
[sPL_4_U]
HiFonics - Alpine
Pioneer - Clarion
Infinity - Kicker
KnuKonceptz
positive power wire? or positive speaker wire? and by jump it you mean put the two together in the remote turn on hole?
Sry, I thought I knew a lot of this stuff, but I've NEVER heard of this method
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
  • Who's Online   0 Members, 0 Anonymous, 537 Guests (See full list)
