ok so would this will be safe then...?
keep the 200amp fuse under the hood after the first battery...
then take the fuse i have infront of the second battery and put it before the RF amp instead or is 200amp too much for it??the amp is reccomended of 150amps...
also i thought u needed a 2nd fuse infront of the 2nd battery to protect the 2nd battery?
just want to do it right you know..i never had a system with 1500+ RMS
my system has been connected all day today but i havent powered the sub amp/subs cuz i dont have the 150 fuse..
so i was wondering if i could do what i wrote in the post previous to this one??
Edited by Mellow18
2001 Black Monte Carlo SS chrome 20''
(1) Alpine i-9881 deck-ipod-
(2) DC lvl 4XL 18''s-Walled-
(1) DAT Hellfire - 2500.1-fused-
(1) D3400 XS Power battery-fused-
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
(1) DC POWER ALT INSTALLED BY ROB FTW,Big3
(1) Viper 5901 Alarm + killer yorkies and chihuahas
[EdgarCervantes] 4:31 pm: im in my room and out of nowere i hear bass im like oh shit sombody has
bass in this city, i look out the window and its my mom bumping Gorilla Zoe
any1?this is the last piece of the puzzle for now,then i just got to set my amp settings..
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
put the 200 amp fuse between the first battery and the second battery.
then get a 150 amp fuse soon for between the amp and second battery.
you should be fine until you get the last fuse.
Wouldnt be thehoe92 without teh purple
k thanks a lot
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
I disagree.
If the wire from the front battery to the rear one shorts out then the 200A fuse on the first battery might pop but the second battery will crank current down the wire and create a fire hazard.
You should always fuse within 12" of the battery on ANY wire that could short out. This means you need to fuse both ends of a wire running from front battery to rear.
The fuses on your amp are really just there to protect things if the amp fails and the power supply goes short-circuit on you. You don't HAVE to have a fuse before the amp, but it doesn't hurt - and if there's a chance that wire could short out another way, you must fuse it.
Edited by Boon
10.x volts fo' life!
thanks for clearing that up Boon,that is exactly the reason why i put 2 fuses on my main power wire
but everyone keeps telling me different but i said Fu*k it and bought a fuse and my friend gave me the holder for free
so i kept both fuses for both batteries
(2) CDT 6.5 comp
(X) pioneer 6x9 set
(1) RF T-400.4
Good info Boon.
The point of a fuse is to cut off power if things go awry. You can shut your car off and your alternator stops putting out power, but it is impossible to turn "off" a battery. If it shorts out, it will give the wire/car everything its got, which is PLENTY of energy to start a fire/weld sheet metal/burn all the wires insulation instantly.
The way to avoid such a situation is to protect every source of "unlimited" current (battery) by fusing EVERY wire coming off a positive battery terminal. Exceptions would be a short jumper to another battery within 18".
As far as what size fuse to run, it's quite simple. The largest fuse you can use would be the one matched to the size of your power cable, which is what you're actually protecting. (1/0 - 350A, 2 awg - 225A, 4 awg - 150A) You can ALWAYS use a smaller fuse, but it may let go if it's smaller than your amp load.
Finally you have a fuse between the second battery and the amp. This fuse serves two purposes, and is crucial for your setup. 1. it protects the amp from pulling too much current and frying itself. 2. this wire goes DIRECTLY to a positive battery terminal, i.e. a source of "unlimited" current, and should this wire come out from the amp's terminal it would weld itself to any grounded surface with no protection.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
alright i ran 1/0 wire from the front batter positive with a 200amp fuse
in the trunk i have a 200amp fuse before the battery
after the battery i plan to put a 150amp fuse for the RF amp...from knu
is this correct???
..2 people told me that i have too many fuses
1 of them was from crutchfield......
You had it right in the first place... Protect both batterys and the amp....
Don't need a fuse before back battery? Ya ok burn up your back battery and save the front, thats smart.. especially when you amp is pullin off back battery.
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
  • Who's Online   1 Member, 0 Anonymous, 666 Guests (See full list)
