Ok so i'm adding another amp so gonna be running 3... Was looking at relays and typed in 30amp electronics and came up with a 20/30 amp and a 30/40 amp... Whys there two numbers? Also you guys think I really need a relay and any of you got any pics of your relay setup? Amps are in Sig if it matters BXi2008 Zx350.4 Zx200.2
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
all you need to do is run a spdt relay its real easy ill help you set that up when i do your alarm if you want
must be nice huh
87 power 85 ground 86 remote wire from deck 30 output to amps
must be nice huh
Ok sounds good... You got an extra then? I searched the spdt 30amp relays and bosch 20/30 and 30/40 came up... with the wireing plug thingy... But didn't know why there 2 numbers
Passport Build Here
Ya I know how to wire it pretty sure but donno what relay to get never bought one
Passport Build Here
i have a few extras dont worry
must be nice huh
Anyone got any pics of there relay setups.. Still would like to see :)
Passport Build Here
i always use 30 as a source and 87 to go to the accessories. i guess it does not really matter unless you are using a relay with a 87a pin and actually use the 87a pin.
DC.jpgDC POWER
well the way i have it setup is correct with a relay with an 87a pin thats all iuse
must be nice huh
yea its fine
Edited by Stephen_C
DC.jpgDC POWER
