L561W Posted March 2, 2009 Report Posted March 2, 2009 I just ordered two dual 2 ohm Type S 12s for my next setup. I will be running them off of an Alpine mono, 600x1 RMS at 2 ohms. I'm going to be building the box soon, and need some suggestions on tuning and what airspace works good for these subs. I listen to mainly rap and some rock here and there. Definitely want to go with vented. The amount of volume isn't really an issue because it's going into a big ass trunk. But just for shits & giggles, max dimensions are 60Wx15Hx30D if I remember correctly. Any suggestions at all are appreciated.
BassBoy69 Posted March 2, 2009 Report Posted March 2, 2009 are you set on building your own box? 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
troy Posted March 2, 2009 Report Posted March 2, 2009 fro those subs you could definately go with a prefab box. however if you realy wanna build a box then just use a box calculator and port calculator{just google search} and build the box to alpines recomended specs. ported the box should be anywhere from 1.25-2ft^3. for rap tune low like 32-34. that should do you right retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
L561W Posted March 2, 2009 Author Report Posted March 2, 2009 are you set on building your own box? Not really. Just thought it would be a better option than prefab.
troy Posted March 2, 2009 Report Posted March 2, 2009 if you are capable of building your own box go for it. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
kryptonite Posted March 2, 2009 Report Posted March 2, 2009 if you want to build your own box, which props to you for thinkin of building one before goin prefab, what i learned from my first box is make 2 in 1. I figured out how much space i have to work with. take that and compare it to the specs for the sub. Than when you build the box, put a divider in the center and make sure each side is equal in cubic footage. Port each side according to the manufacturing specs and it'll pound like a bitch. Lots of guys run a common box with one port for a pair, quad, or more subs. It sounds just as good it's just with a 2 in 1 you know that you have the correct specs and don't have to worry about much. Atleast that's what i've learned from my first few boxes. DC SOUND LAB NUT HUGGERCurrently Own 4 - 18" lvl 6s (m3) w/full Carbon Fiber option 2 - DC 5k lvl 4 motor lvl 2 motor On 8/2/2013 at 8:13 PM, n8ball2013 said: this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
