Alright well I added an amp to my car for testing. I unplugged the battery and had to plug it back in and when I tried to start it, it had troubles starting because of the disconnectoin of the battery. So When I went to start it I also tried to put a cd in. The cd was just sitting half way in so while I tried to start it again and just pushed the cd in. The cd player will not read it, and it cannot eject it becuase it doesn't see it as it's in there.
It is a 2002 ford explorer, and it is the regular (not 6 disc) cd changer. I read to either grab it with plyers (can't find needle nose small enough) or take it out. I don't know how to take it out either so can someone help!
2002 ford explorer
200 amp rewound alt
single 18" Fi btl fully loaded
2 1750's
2 c&d tech 88amp/hr batts
2 ought wiring
cdt component set up front, cdt coaxials in back
Kenwood eXcelon KDC-X693
use two shape knifes or somthing to pinch the disc, .. maybe a picture will help us get an ideal on what to tell you.
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
Slide another CD under it and press the eject button, sometimes that works.
Team T3 Audio
Team Sundown Audio
Team O.B.M
Operation Beast Mode
"Believe half of what you see and none of what you hear"
wigglez that was a bit over the top, i dont want to invison dw giving any young lady a "cream pie" let alone "throat babies".
iv seen some stock units, have the small pin hole button the alows you to get the cd out, ..
best to have a picture, if all else fails..
6" Aero Ported Box
Pioneer Deck
theres nothing to really show.... its stuck in there u can't see it. I'll try the knife thing, i'll try the cd under it too. How far should I push it in there to go under neath it?
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
Press the eject button and slide the CD under the one that is in there. Try it back and forth and continue to press eject, if that doesn't work then try the knife thing.
Team T3 Audio
Team Sundown Audio
Team O.B.M
didn't work. I must have done it wrong. I cant pinch it will enough to pull it out! I REALLY need to fix this.... my dad will KILL me
2002 ford explorer
200 amp rewound alt
2 1750's
2 ought wiring
get a hook tool, slide it in basically level and centered, but pushed up (so it slides over the cd), twist it so the point pokes down on the cd and move around until you find the hole, then pull it out
i've done it sooooooo many times when stock cd players die on customers and they want the cd back, or children stick like 4 in there
second one from the right is basicallly what i use
Team DC
take another cd and push it in half way so the cd player tries to pull it in then yank it out and the cd player will think it pulled in the cd and now u can eject the one jammed in there
Edited by ryde2idie
Quote
that happened to me once, all i did was take another cd an push the other one alittle farther in an then ejected it, its probly just barely not in all the way
Build log: Click
Feedback: http://www.stevemead...xbccp-feedback/
03 Chevy Blazer
- IPad Air 2
- ALPINE Head Unit
- 4 DC XL 18s
- 2 DC 3.5k
- ALPINE TYPE R 5.25 COMP
- 3 ALPINE TYPE R 6.5 COMPs
- DC 175.4
- DC HO Alt
- D3400
- 4 XP3000s
- KNU 0ga
- 60 SqFt Damp Pro
Lots more...
